BudW water pump pulleys
Remow2112
BudW, if I understood correctly it would be a safe bet that a 318 water pump from a 1981 or later M body should have the bigger bearings and they were all AC?
Remow2112
Rockauto for a 1985 Dodge Diplomat show a Hi performance water pump for $50 AIRTEX AW7103H. It has 6 blades and an anti-cavitation plate. I will probably run with this and the smaller pulley.
This was a much deeper rabbit hole then I expected! LOL
volare 1977
I have somewhere around here that 3751126 pulley. I have no idea what I pulled it off of though.
For long term use or for driving hard (like I like to do), I would HIGHLY recommend the newer pump with larger bearings. That said, one can't discount the blade count differences.
After '82ish (not sure of the cutoff), all of the non-A/C cars used the same pulleys and brackets - but have an idler pulley mounted where the A/C compressor is at (on non-A/C cars).
You'd think they would have either used different water pumps or different pulleys but not both.
I've never had non a.c. M but do have non a.c. In my Lil red express.
I also have 82,84,85 m's to compare parts on as well as a 79 a.c. 360 in my 88 and the parts from the 88 318. This is almost getting me curious to check.
How in the heck did people even walk in the daylight before the internet?
