Fender Blinkers
DCAspen
ct.
I need the measurements to mount a set of fender blinkers on my car,Can anyone help?
I don't have any measurements (yet), for need to mount some turn signal lamps to my '77 Volare Fenders.
I have a question for you – that might make a difference – you want measurements for what year and model car?
Thanks Bud,They are for my 77',I already have the measurements,76-79 are the same,no fender blinkers in 80',except in Canada.
From the front corner of the fender next to the hood,7 3/4" toward the windsheild,1 1/16" across the fender top,that mark will be the center of an 11/16 hole where the light socket comes thru from underneath.A small hole for the screw to mount it to the fender once it is straight.
Sorry it took so long,Been focused on working on my car
Thanks DCAspen. I have a nice set to put on OY someday, and needed to know the exact measurements. Unfortunately, OY doesn't have the pigtails on the wiring, so I will have to splice them in, but no real problem.
Well, that's interesting, and I hope that perhaps they are taped to the harness, but I am fairly certain that they simply aren't there. I'll have to take a look again this weekend. Thanks Bud.
My daugther's 78 Volare had the loose pigtails...
What are the measurements for mounting the fender mounted turn signals. I may want to add them to my car.
Thanks!
From post #6
From the front corner of the fender next to the hood, 7-3/4" toward the windshield, 1-1/16" across the fender top, that mark will be the center of an 11/16 hole where the light socket comes thru from underneath. A small hole for the screw to mount it to the fender once it is straight.
This thread should be a sticky thread,So other people can get the info.
