FMJ Engine startup 2020
SixBanger
The Netherlands
Someone in for to upload a videos of start up your mopar engine (cold start) before it goes to New Year 2020? Can possibly make a compilation of different videos/engines FMJ Engine 2020.
I’m game.
It’s about -4 celsius here and my car’s been sitting for about 14 hours.
I’ll make a video when I get home later this afternoon.
I'm out. Would have to excavate it out of the garage just to open the doors at this point. :confused: When it's in for the winter, it' in.
78VOLAREWAG
PITTSBURGH PA
Okay, when I get home tonight, I'll fire up my wagon. It's sitting outside, covered in snow and hasn't been started in about 3 weeks.
If I could post the video, I would. Deleted my You-Tube acct a few months ago. Don't ask but, I had my reasons. Same reasons I also deleted my FB acct around the same time.
There isn't a way to upload the video directly from my computer to this site, is there???
Same as Duke5A here...done for the year...but I've got some YouTube floaters out there...search for "1980 dodge diplomat coupe"...higher quality stuff on my home computer though!
seeing as I don't have a running engine in mine it would be pretty difficult right now......I can post a gen3 Hemi startup
SixBanger
The Netherlands
Aspen500, for me only Youtube account and some different forums no FB sites anymore. I think video file would be to large to send it by email. But ever heard of WeTransfer ?
Great snow cold start 78volarewag. Starts just like every casual morning.
80mirada gen3 Hemi startup is also good to go.
78VOLAREWAG
PITTSBURGH PA
I just got a new hemi Ram with the 8 speed auto, the power is rediculously wicked.
Cold start this afternoon. Had been sitting for a day and it’s about 37 degrees out today. Had to record this a couple times during the week before I realized, I needed to take my phone out of its case so I could get half decent audio lol
SixBanger
The Netherlands
Great cold start Camtron! Also see that you are busy around different diff, still planing to include the rear disc brakes conversion (jeep or other)?
Oh yes, my friend.
I have a new Dana Spicer limited slip, 3.21 gear & pinion and fresh bearings all ready to go in. Just waiting for a good time to get the brake components so I can throw it all into the car at once. I wanted to have it done last month but, life gets in the way of things sometimes; Hopefully, it will all be done and in the car by Spring this year.
Oh yes, my friend.
Rear disc? Don't forget to replace the proportion valve with a distribution block.
Oh, it is on the list. There’s a real nice Charger build I was watching for awhile and I’d be a liar if I didn’t say, I want to recreate it. A lot of Wilwood parts with a real nice in cab, brake bias adjustment under the dash...It’s a 3 pedal conversion too, but I won’t be going that route myself; lucky duck.
Similar to yourself, a well planned manual brake conversion has been on my mind. I only want to spend big money on brakes once lol
Removing the rear axles are not easy and best to be done one (1) time, so doing both repairs (limited slip and brakes) at the same time is a good game plan.
One thing to look for on the 8¼” axle shafts are the area where the wheel bearing rides at.
If this surface is discolored or if it will catch a fingernail then you WILL need to replace the wheel bearings while the axles are out. The good news is the axles are still useable (if damaged by the bearing) - if you use the new design of offset wheel bearing(s).
If an axle is bent, then no – time to toss (or repurpose).
Normal (8¼”) axle bearing (and seal – which is normally a separate part).
Koyo AK1559, Centric 41368000, SKF SX4814, Timken F390 (and others)
Or the new style offset bearing
SKF R1559, Centric 41468000, Timken TRP1563TAV (and others).
Wow, three petals and neither of them which won’t help you change gears.
It looks like one of those is a cylinder for a hydraulic clutch. I'm guessing...
one pedal is a clutch...”three pedal conversion” you guys know of any car with two brake pedals? I sure don’t...that other pedal is a clutch (hence I wouldn’t be going that exact route)
