Ford 8.8
Mopar&vettedude
Tonwanda, ny
So after finding out I have the 7.25 rear instead of the 8.25 (though it Looks like one), im going to go with a ford 8.8 out of the 95 and later explorers. Is there anything that needs to be done suspension and drive line wise that I need to tackle to make it fit with ease?
Aren't they on top of the axle housing? It's been a few years since I did mine.
It's not likely that the pinion angle will be correct for the mopar.
It looks like the axle is about 4" wider than F/J/M axles. You're going to have to cut it down and put on new spring pads. What I would do is find one from a 95+ Explorer to get the disc brakes and take it in to an axle shop along with your old one. Tell them to set it up to the same dimension and angle as the old 7.25". Be sure to have them take the thickness of the caliper bracket into account.
If you plan on doing an ISO delete at the same time you'll need slightly different spring pads.
Don't get discouraged, this is pretty standard stuff and having an axle cut down isn't that pricey.
Opticon77
SE PA
I thought the track was 59" wide vs our 58.5"-59.5".
The popular fix for the 8.8 is to cut 2 7/8 off the long end and use another short axle in that side. If you look on Utube there are plenty of videos doing this. Now what I did because I live 80 miles from Ames Iowa I took my housing to Quick Performance and had them narrow the housing and put 9" ends on it, they also welded the tubes to the center and provided me with new axles. What this did was eliminate the need for a C clip in the center section and gave me a fully prepped assembly.
All for $700 and there work was beautiful. I addressed the yoke with a Strange 1350 yoke and spacer kit, no crush sleeve, rebuilt the Locker diff as Ford calls it with a carbon fiber clutch kit. I actually narrowed my axle 5" for my little Ford, all in I have about a grand in it.
Mopar&vettedude
Tonwanda, ny
I had a feeling that was probably going to happen, that's why I havent picked up the rear end yet. The shop should able to find the correct spring perches right? And the 1350 yoke is that for the driveshaft end to acommidate for the ford flange on the axle?
Strange and Moser Engineering have the yoke.
I used a shim and spacer kit to replace the crush sleeve from Quick Performance, they should have a yoke also.
Ford 8.8 (8.8" Ford)
Mopar&vettedude
Tonwanda, ny
Ok . cool. So all I would need to do is grab another short axle from another explorer and pick up these parts and i should be good to go.
Yep:)
There are videos on utube on this if you haven't looked.
8T2TOP
Phoenix
For ALL that hassle,I'm sure you could aquire a 8.25 for $150 then it would fit CORRECTLY and parts are plenty and cheap..
I'm just curious about how much power you have? Do you need an axle that can stand up to 500 or more horsepower?
Opticon77
SE PA
Note that a ring/pinion set and a limited slip for a 8.25" already puts you over $700 in parts alone. Where most 8.8s already come with 3.73 gears and a TracLok differential along with holding twice the power.
8T2TOP
Phoenix
Then get a 8.25 from a jeep with discs,posi,plethora of gears...
But,hey Go nuts..
Mopar&vettedude
Tonwanda, ny
Its more of a over build of the car. In case i do put a 500+ horse motor in the car down the road. No sense in making it difficult for myself later on. And what jeeps?
