Hemi RT aspen Wagon
some more progress today got the master cylinder installed and plumbed in fan installed and fully wired ground cable changed fuel lines and filter installed
now i move onto the trans filter and gaskets drive shaft and exhaust
you can see the ride height that needs to be lowered way too much space above the wheel
another good pic of how high the front sits
With that ride height you could drive down the road with the front of the car bouncing off of the pavement. A little lift fropm the wind, and a bouncing you would go.:D
well here it goes first start not the best vid but its a start this is the fisrt time the engine has been started so there are setting to be done like floats need to be set timing and exhaust needs to be installed this was a test fire only
time for an update gallipin Gerdy got a Xmass gift a new set of carbs 1404's and now its runnin absolutely the way it is supposed to
here is a clip of the new run
