1. creeds_247
    creeds_247 Active Member
    36
    Mar 14, 2011
    Where can I get solid motor mounts for my 76 volare
  2. bremereric
    bremereric FMJ Body Moderator
    3,555
    220
    Feb 25, 2011
    Jackson Missouri
  3. ramenth
    ramenth Well-Known Member
    906
    96
    Beaver Dams, NY
    Solid motor mounts? Seems to me you might be able to make 'em on the cheap. Or run urethane and build a torque strap for it.
  4. bremereric
    3,555
    220
    Feb 25, 2011
    Jackson Missouri
    You can get the polyurethane ones and torque strap both a Schumacher Creative...also tranny mount..
  5. Dago Red
    Dago Red Well-Known Member
    171
    7
    Mar 12, 2011
    Fort Worth, Texas
    So Easy a Caveman Could Do It
    Make them yourself (with the help of a good welder). Just like Brother Rameth said.
    Just knock out the rubber insert and sleeve, weld some scrap steel caps on each end, drill holes in the center of the new cap and Viola'
    Done it three times, they work like a dream.
    Just make sure you shim up any spaces between the width of the modified mounts and engine mount cradles, or you'll be replacing tranny mounts or tailshafts. AND DON'T ASK ME HOW I KNOW!!!:icon_wink:
  6. ramenth
    906
    96
    Beaver Dams, NY
    Ouch!
  7. ramenth
    906
    96
    Beaver Dams, NY
    Not sure how there torque strap mounts up to the bigger F/J/M k-frames. I saw what you're posting about, Eric. One of the pages says for A,B,F,M,J-bodies while if you click on the torque straps themselves they only list 'em for the A, B, & E. Even the installation guide shows only the A, B, & E's, with just a little disclaimer which says "all other years, holes must be drilled." Does that mean that you have to drill holes for the earlier A's and B's? Or does that mean for the F/M/J's, too? I don't know. I think before I bought one I'd have to make a phone call to see if it's designed to be a direct bolt in. Failing that I guess you could always just use the torque strap itself and fab up a new bracket, if the situation called for it.
  8. creeds_247
    36
    Mar 14, 2011
    Thanks for the tips. Im quit have all the tools to make a good set easy but may try to weld up a stock set.
  9. bremereric
    3,555
    220
    Feb 25, 2011
    Jackson Missouri
    You have to drill holes...the f-body k-frame is a strange animal...I just looked at mine since it's out of the car and it would take some thinking about it but it could be done...main thing is there it not a flat place to bolt it near the motor mount...you may have to weld a flat piece of steel to mount it to..
  10. Dago Red
    171
    7
    Mar 12, 2011
    Fort Worth, Texas
    Let Me Say This About That
    While we're in this neighborhood......................:confused3:
    Is there anyone who is making metal K-frame isolators?
    Mopar Performance used to offer a set years ago, but has discontinued them.
    I keep hearing rumors, but haven't seen anything yet.:icon_study:
  11. MiradaMegacab
    MiradaMegacab Well-Known Member
    1,619
    422
    Long Island NY
  12. A38Valiant
    A38Valiant Well-Known Member
    62
    Woodward, PA in the sticks
    Meanwhile, back to solid spool mounts..... A few years back I found a length of brass round stock in a scrap pile at a yard that happened to be the right diameter to fit inside the brackets after torching out the rubber. Simply cut to length with a hacksaw, and drill the correct size hole in the center. Lotta elbow grease with the hacksaw, but the mount conversion was truly a low-tech, low budget deal that worked. Plus, I think the brass was probably a little kinder to the thru-bolt than steel woulda been. Just wish I knew what size brass stock to buy, as I'd like to do another set or two....
  13. creeds_247
    36
    Mar 14, 2011
    Got me a set of factory mounts and got them welded up solid. Thanks everyone for the help..
  14. MeMike
    MeMike Well-Known Member
    56
    Mar 14, 2011
    The Natural State
    Always put a shout out for or NAPA Auto parts countermen we have here in our area :icon_cool:
    I bet allot of you know what it's like to talk to a good tech behind the counter :icon_biggrin:,
    No it's not a front wheel drive car :D
    I LMAO at some countermen, I do understand they are just learning.
  15. bremereric
    3,555
    220
    Feb 25, 2011
    Jackson Missouri
    Have MeMike take a picture of them and post it for us
  16. creeds_247
    36
    Mar 14, 2011
    Ive got pics on my computer but cant get them to upload. Ill email them to dad.
