volare 1977
X, not sure why you are so concerned about what he puts on his car. Anyhow, are far as the t/s question. Can you give me some part numbers that show with or without provisions for the fender t/s ind. My 77 book show eng compartment wiring 4055141 and 4055139 for a 318 equipped HN car. The only difference between the two is with or without S92 S94 S95 S96 sales codes which are lean burn and emissions related. The H/light and dash panel wiring listed are 4055151 for 41 50 60 amp alt and 4055156 for 65 amp. 4055390 for 100 amp. Again no reference to the t/s indicator wiring. So I do not see anywhere the factory shows a different part number for the t/s indicator provisions. Sure there different harnesses for different engine size etc but what i was saying is the connection for the indicator should be there as the parts book book does not show different part number based on that item. Also from what I remember all the F bodies I have owned had the connector. What is the part number of the harnesses you have there with no indicator provision?
