Dont scare him lol You're not replacing the whole thing. Cut chunks out bigger then the rusted areas and a body shop or anyone decent at welding can replace those sections.
That F body panel has everything you need and should be the same for those areas. Just sayin.... too bad its not your bad side.
SonOfaTomP
Baltimore
Here's a Volare quarter, probably won't fit, but you can see where the edges are where it gets welded to the car, which will help you figure out where to cut. Link:
that's a huge help. 84 New Yorker is an M right? theres one in Pennsylvania that might get sacrificed. if not one in Delaware that might as a bonus have the red seats i want for my maroon car
that or i can see if i can get back in contact with the guy with that white car you took the header off of
Go for the one with red seats, because if the quarters aren't any good at least you can get the seats.
Idk how much better that white car was, and if i recall correctly, the trunk didn't even open, so its not like you could even check down inside and see if it's rotten.
It depends on if they used the right name or not. 84 new Yorker is K-car but it's obvious what it is from pics.
SonOfaTomP
Baltimore
both sites had no pictures. just listed it as New Yorker (RWD) 82 was NYer, 83 NYer Fifth Ave, then 84 is just Fifth Ave? i'd hate to drive the two hours then find just a K Car. but those were all FWD
If it does say rwd it's the right one.
Yeah the name game with them is confusing. Thsts why a lot of parts places just called it full size or rwd rather them the model name.. same issue with Cadillac fleetwood identity crisis going back and forth between fwd and rwd.
SonOfaTomP
Baltimore
found a picture of this car in old family photos. yep, it was always grey it seems. had a repaint when the Plymouth header panel was put on i remember that.
new plugs, wires, cap, rotor. acceleration stumble is gone. that was simple. carb is leaking though. needs rebuild. wipers still don't work. will likely need a new switch. even the spray nozzles don't work.
made sure to check under the wheel well trims of my Plymouth. to my dismay i can see rot starting there. very minor bubbling now. made sure to clean em up really good.
hunting for quarter panels now. might have one lined up.
Pop those bubbles, sand the area down to remove the rust. If you want to be surgical, use a Dremel. Clean with acetone or brake cleaner.
Treat with ospho
Paint with rusty metal primer, several coats
Is this the "professional" way to do it? Hell no. Will it slow the rust and preserve the car? Yes. Is it cheap? Yup. If it's behind the trim, you can use the trim to hide your work after and keep enjoying the car
SonOfaTomP
Baltimore
thanks AMC. gotta track down a good Black Cherry spray paint. or just get really good at taping off the fender. rust is only on a few paint chips and on the driver's side rear quarter. hidden on the underside and under the skirt. and one or two tiny bubbles around the window, those will be hard to hide. how easy are those rear window trims to take on and off? some paint chipped off there. filled in with a touch up pen but it really came out looking black
your tips have definitely taught be this task isn't as daunting as it seemed at first. gonna try and do these cars right
With a trim removal tool, the window trim pops right off
I'm 100% a hack and I don't do anything the right way.
SonOfaTomP
Baltimore
Happy Fourth!
cleaning Bulldog up getting ready to fill some of the rust holes. put the emblems back on. did i get the spacing correct. i did 2 1/2 inches up, 1 1/2 from the edge. i only had my Gran Fury and photos as reference. you can somewhat see the shadow of where this had a SE Diplomat badge formerly.
odd thing with the front bumper fill, it has notches cut out. was also in three pieces in the trunk.
going to test my rust filler skills on this hole near the rear door fist. I've only ever filled in drywall holes so this will be fun. got some mesh today and fill get my fiberglass filler soon.
correct color for the tail light surrounds? these are both chrome and silver right? these are quite faded and have old taxi paint on them. red and yellow
