Bruceynz
Hi Guys,
Ok sorry if this has been asked before, I had a look and didn't see a posting on this, I am going from a stock 318 to a warm 360, not to radical but with some help of other forum members I have bought a cam that will work nicely in a 360 to go with J heads with 2.02 valves. I think with the set up we will be between 300 - 350hp. I currently have an 7.25" rear end but will upgraded that to a 8.25" 3.21:1 ratio. My concern is my 904 A998 trans going to cope, I am not going drag racing, maybe the odd spirited take off at the lights If it won't last will the 904 be ok if an extra clutch pack is added to make it into a A999 trans or should I go 727?
Or is there a rebuild kit or parts readily available that will strengthen the 904 to what I want?
The reason I like the 904 is I have it already, light, lots of parts on ebay for it - I see rebuild kits for $150.
Also will my drive shaft need to change length when I go from a 7.25" to an 8.25"?
Thanks
Bruce
Thanks
Bruce
