One more "complication" regarding these parking-wiper systems. The way they work, is that when you turn the wiper switch to off, note that the wipers reverse directions. What happens is the switch sends reverse-polarity voltage to the motor which makes it rotate backwards. There is a contact that causes the motor to rotate backwards, and after a pre-set location is reached, the contact is lifted from the wipe, causing the motor to stop. The geometry of the drive crank linkage causes the wipers to be pulled further down (and into the cowl) than they do when "regular" polarity voltage is applied to the motor. The poor-parking may not be caused by the drive crank: It is often caused by deterioration of that contact and wipe that signals the motor to rotate backwards to the set point. If that circuit isn't working, when you turn your wipers off, they'll just stop right where they are, often mid-window. Mine work pretty good, but now and then when I turn them off, they'll just stop where they are instead or parking. Turning them on and off a few times, essentially exercising that contact and wipe like you would a scratchy volume control, cures the problem.
Also, if you happen to install the drive crank 180 out of phase (it fits on the motor two ways), really bad things happen.. Like the wipers will swipe way off the glass on one side, and try to smash into the cowl on the other. Ask me how I know!
I know a few guys have done away with the parking mechanism altogether with some garage engineering.... It fixes the wipers, but they don't park. J-bodies look awful with the wipers on the glass.
