My first post and it's a doozy
Gunnar Schroder
Norway and Sweden
Oh dear me what a lot of work done and still struggling to make it running as it should. I noted one thing that I want to comment.
I have this G22 1978 bought in 1991 and ran till 2000 when mothballed. Pulled out again in 2022. Mid 1990 I threw out the Spark Control Computer and replaced everything needed with the Electronic Ignition system as per attached photo. Threw out the Thermoquad carb that caused some idling problem (The importer could not get it run properly; I did!) and put a Edelbrock instead. Ran perfect all those years before stored.
Then when I started to renovate her in 2022 I bought some new items from Rockauto. You see them in the picture below: Ignition module to the left and the control module in the rear of the window washer tank. (Sorry I have forgotten the names but I am sure you understand) She ran as in those long gone days.
Then to the point:
A new coil and ballast resistor bought from Rockford as they advice to do so (cost was only coffe money). Replaced those items and started her up.
She started all right and warmed up most at idle for a while. Then: Shifting gear to drive she struggled and struggled and hardly ran at all. Just as this one. Hmmmmm what to do? A cup of coffe and a short rest. Then I checked it over again and the only thing that was different was the BALLAST RESISTOR. The original in the set had two point connection but the new one had four. Old one dusted off and replaced the new one. Hey! Presto! Back to normal and long gone days.
She now runs and idles perfect as she did and should do.
So: What about the Ballast Resistor??? According to Rockauto the new one should be compatible with the old one. NO!!!
Take care all of you and any of you have experience with AMSOS? I have filled in their formular and asked for prices etc for a few items several times but not heard anything. Perhaps they do not sell to non-USA members? I need the rear wheelarch list and they seem to have it.
All good wishes from Norway
Gunnar
Then to the point:
Gunnar
AMS Obsolete/AMS NOS is the kind of place that likes phone calls over emails.
Gunnar Schroder
Norway and Sweden
I know but phoning from Norway and my language is not so good. I hope some of our members here had time to help me asking them for a quotation. I do not rely 100% on myself speaking and may mess things up. Thanks for informing me Sir
A single ballast resistor will work or they won't... when they don't work engine stops when you let go of the key after starting.
For AMS what were you buying?
Gunnar Schroder
Norway and Sweden
I must check the restistor I bought as you gave me an idea. Perhaps I can use only two of the connections? I seem to recall (when looking underneath it that there were two paralell restistor wires? Thanks a million Mike.
A different kettle of fish now as the parts I have asked for are as follows:
4054457
The rear weatherstrip for my sunroof (still working!) The front one should be nice to have too so please check if you have any part number for that. I have not found it in the Spares manual I have.
4017808
I presume this is the rear wheel arch list I am missing for my G22 !978 Coupe Dodge Diplomat
4046915
I have only got hold of one new bumper guard and would like to have one more. My Dodge is a 1978 G22 Coupe that I bought way back in 1991. Restoring her at the moment.
All in all at the moment three Items: 4154457, 4017808, 404695
Payment prompt either Paypal or Mastercard all inclusive freight to Norway.
I kept a copy of what I filled in and the only one I am really in need of are the Rear Wheel Arch 4017808 as the one I still have was run over by me in our garage late 1990! One of the rear bumper guard may be resused as the chrome is very good but the inside! Rusted but cleaned up by me and stopped (I hope) with some paint sealant (or so they say).
Still good weather over here and Saturday is the Norwegian National Day.
Take care, safe driving and too many idiots on the road over here with E-cars.
Gunnar
69-
Germany
Using only one pair of the resistor is a possibility. Should work like a charm.
On the dual ballast one side should be around the proper resistance and the other side isn't. If you're using it in place of the single one.
5thtimesthecharm
Took my carb off, blew out the idle passages and rod passages with carb clean and quick air blasts. Then adjusted the butterflies, looked like one of the primaries was a little off. That cleaned up the idle really nicely. No longer rumbles like crazy after adjusting the a/f screws.
Now timing. Just to be sure, I doubt and triple checked. My wires are set correctly, and TDC is where it should be.
But I noticed that at TDC my harmonic shows retarded 4° or maybe 5°.
Should it not be lined up with the zero at TDC? Or did some emissions motors come with that retard from the factory?
Gunnar Schroder
Norway and Sweden
New China crap?
Maybe. I will check it over when I dash over next week. There is nothing like original parts. Same with my motorcycles. Original Noton stuff works splendid (1958 model 99) and so do my own cylinder head gaskets made by solid copper to my Brough Superior SS80 from 1938.. The ones I bought from a chap in Austria who owns the name Brough Superior are CRAP! Two blown in 200 km
To find true TDC, turn until the piston stops, and mark the balancer. Then keep turning until the piston just starts moving back down, and mark balancer. TDC is halfway between the 2 marks. It's most accurate using a dial indicator, but for a stock, street use engine a screwdriver is close enough.
5thtimesthecharm
So for clarity, still sounds like a slipped harmonic? I don't imagine there would be a 4-5° difference between the pistons peak and the beginning of its return trip, or am I wrong to assume that?
4-5 isn't much. I'd imagine TDC would last for some slight turnage but less then that but then again that's also not much for it to slip either.
5thtimesthecharm
Question for all.
My fan clutch is starting to catch even at idle on initial start, so in for a new clutch.
Question being should I just replace the clutch and leave it be?
Or switch to a flex blade fan, or swap to electric fans? I know those options are more expensive. Just wondering if it would be beneficial, and if so I can get everything together.
Currently have the clutch and 5 blade fan setup.
Car only gets to the second notch on the temp gauge, never seen it go higher than halfway past that even on plus 25° days.
