- Joined
- Apr 26, 2016
- Messages
- 1,296
- Reaction score
- 306
Well I think it's best to wait and see what exactly rear gear is in there now.......
Fair enough, I still want to see if I'm satisfied with just the 2bbl, probably won't be, and in the meantime I'll keep looking for the appropriate parts to make it better if need beThe 2bbl won't do much below the torque peak, which might translate to as high as 27mph, depending on your gears and tune. That big single is not that bad!
I've had ripper slantys with single barrels, and I've had slanty dogs with 2bbls...
Gears can make a dog into a ripper, and vice-versa..
No its the paper hose the goes from the base of the cleaner assembly to the outsideAre you perhaps referring to the heated air intake, with the corrugated black shaped hose that appears to be connected to the exhaust ?
If that's the case what is the best way to go about getting the snapped bolts out of the exhaust manifold?Good question!
no
bad answer![]()
Haha yea unfortunately I doubt there's enough of it to help me keep both both from snappingLordy... you sound like you need some good kharma..
