Lucky Charms
Ha ha, autocorrect must have been onNo Mother? Father?
They are actually Crane RockersThose look like mopar rockers...
I've got a 440 in my Volare with 2" headers so my problem with the same tube was more severe, I needed to moved the steering column over and got rid of the rag joint.
I feel like 30 years ago, this would have been done in a week. I pretty much commit to putting at least 10 hours a week in to the project. The only thing slowing me down is the availability of parts.Could you let me in on your secret to getting so much done in so little time?
I'll be turning 51 next week. Definitely slowing down a bit, but not making as many mistakes as I used too, so maybe it's balancing out...Thirty years ago I did get a ton more done than I do now. The difference between being 27 vs 57 I guess
Thank you Paul. I will keep an eye on it. The crossmember seems pretty sturdy, but I will go over everything after I put a few hundred miles on the car.I am not that familiar with Volare/Aspen models. Mopar used 2 bolts per side in previous cars like B and E body's. If there is only 1 bolt per side in floor support, that is all they used. If you are not planning crazy big power it might be enough. That 383 is probably going to make 400Ft#'s. After you have some miles on it I would take a look at the cross member again, just to be sure it can hold the power.
Thanks Bud for the info. That makes complete sense nowF and M-bodies (and some J's) all use 2-bolt (total) crossmembers.
All other Chrysler Rear Wheel Drive cars use 4-bolt crossmembers - which I think was because of the rear torsion bar stress.
I wanted to post a video of the car. Not sure how to upload or attach. Any ideas?
