Cleaned out my garage to make room for another car
One more little project completed.
Okay first of all I visited my M-Body at the storage and the M-Body battery strut is the same. So next time I go junk yarding I see if I can snag a few.
On a previous junk yard visit I got this and painted it this weekend.
Then I did paint the battery strut rod but did it in white instead of black. It contrasts good against the black of the wiring harness and air intake hose. I also placed it underneath the brace instead of on top of the brace. This would have wrecked the white paint underneath the bolt.
Rear sway bar done
I got it installed but won't do it shame with anymore nightime photos. I had to shim the bottom of the Firm Feel brackets with one inside washer on the outer bottom and two inside washers on the inside bottom. I did it by myself and scratched it a little. No harm cause you can only see some of the gray powder coating underneath. So hear goes some moring pics and will drive it on Saturday in 72 degree weather. :icon_cheers:
Had a issue with the stock exhaust manifold gasket. I finally took the time to replace it. I used a little high temp silicone at the problem area this time.
