Got the air cleaner on and received the louvers
Got the air cleaner on tonight...it looks good to me...will even look better with the 318 4 BBL cap on it...started her up and checked for fuel leaks...everything was great and I found out what was making the throttle stick sometimes...if you use a two barrel throttle cable holder on a 4 barrel carb it is too far towards the center of the intake..I bent it over towards the valve cover and wah la it fixed that problem..still have to find a hose to connect the breather to the air cleaner...
The louvers showed up...I scraped off the butle tape and then got the remainder off with mineral spirits...I tried mineral spirits for cleaning the paint off of the other side and no wano...any ideas from others on how to remove paint from plastic? Anyways here is what they will look like...minus the tape and black coloring....
This what the nasty butle tape looked like...
