Bruceynz
Fords last offering
GMs last offering
Chrysler last offering
Mitsubishi's last offering designed in Australia
No matter what the power output, there's still just nothing like the SOUND of a V-8! Whether it's a big block Mopar or the hi-po Audi 4.2L (ever hear one of those at 8,500 rpm?). Of course any Mopar V-8 sounds the best of allOnly V-8's that sound like crap are those with a flat plane crankshaft, like a Ferrari or (I think) some sub-model of a new Mustang. They sound more like a pair of 4 cyl's running side by side.
Main thing with the new engines, turbo or not, is oil changes and use synthetic oil. Even without a turbo, the variable valve timing system has small oil ports that don't take much to get plugged. With direct injection, there's the problem of carbon build up on the intake valves caused by oil vapor through the pcv system (no fuel to keep them clean). Synthetic doesn't vaporize as much or cause carbon/varnish and oil vaporizes more the more it breaks down from use and heat. At work, the cars that we tear engines apart for repair, or replace a turbo, etc are almost always the ones that have had 8,000 mile oil changes and use conventional oil. Just did timing chains on a Nissan Murano with 78,000 miles, a $3,800 job. Cause? Not changing the oil (according to the sticker, it had been almost 9,000 miles since it was last changed, besides being over 2 quarts low). On the flip side, we have customers with the same vehicle that change oil every 3,000-5,000 miles and use synthetic oil with 250,000 and the engine has never been opened.
Now why would you do that?First night I had car I disconnected pcv, extended pipe so it now exits onto the road, probably upset the greenies but as we all drive v8s with relatively no emissions on this forum I dont think i will upset anyone.![]()
