I was wrong. The OHM reading on the
NEW pickup coil is 385, not 285, and it does run much better now, but OY still has that intermittent, annoying "bucking" when just crusing along in either 3rd or 4th gear. My friend says the Chrysler factory manual lists OHMs should be "between 100 to 900".
Well, if that's the case, then even the old pickup coil in the distributor should have been fine - BUT replacing it, did seem to make a significant difference.
I'm going to replace the
ignition coil next as that seems to be a likely culprit - thank you Aspen 500 for that suggestion!
The
plugs are Champions which were new last year. I never had a problem with them before, but who knows.
As for the
ignition module, I see that it was replaced at some point in the past with a "Big A" brand. Not sure why someone would have had to replace that with only 27,000 miles on it when I bought it. I wonder if that could be messed up?
I'm doing a lot of work to OY right now, and will update when I get a chance, but this problem with what seems to be ignition is mystifying. The wonderful
Super Six is such a simple engine, that I am frustrated that I can't seem to solve this problem, even with my limited mechanical skills.
Any help or insights would be greatly appreciated!
