Use vice grips on it if a socket no longer works.
Hit up a junk yard for a matching spare if you don't line the look of a normal nut (I wouldnt).
LSM360
Melbourne, Florida
I don't see a headlight flasher module where I usually see them mounted (rad support in front of battery) but maybe it had one. Wondering if some of your wires went to that.
SonOfaTomP
Baltimore
i'll try and get pics of what looks like the former police equipment when i can. there is a GE fusebox on the passenger side and some old cut grounds on the drivers side.
SonOfaTomP
Baltimore
would the wiper assembly off a RamCharger work? local yard has one. i might still be able to get those police rims too if they picked it back up. last time i was there the thing had fallen over
i believe they all had the more common 3 bolt style pivots. those won't fit an FMJ body
SonOfaTomP
Baltimore
and i thought fiberglass was a ghetto fix. not going to lie. it looks like it'd work. says it can be sanded. hmmm. maybe for patching the interior of the trunk not the exterior
If you're going to patch like that you might as well use the metal mesh stuff some of the Bono kits come with. Or do the real lazy way and use the silver metal duct tape.
I'm tempted to try it on an old truck bed. I don't think it's pretty but definitely functional and easier than using short strand fiberglass.
Imagine if they sold in long strips for hillbilly rocker panel "replacement"
You honestly can't make the car any worse if you cut quarters off a 5th ave and hang them yourself. Will it be perfect? Maybe! Who knows until you try!
Or you could cut the quarters off and take it to a collision shop, and then they can cut off the old ones and put the 5th ave ones on
There are tons of videos about quarter panels and body work. This is a Honda civic, but it's the same idea
It's tedious work, but not impossible work to do in a driveway. Cut up a 5th ave and see how it goes
SonOfaTomP
Baltimore
IIRC they are usually branded Code 3 or Whelen
the only remaining police equipment i could find in the engine bay. couldn't find a wigwag module. there are holes in the body the cops never plugged where antennae used to be. and some holes where i'm guessing there were rear deck lights.
working to get a new quarter panel. got one lined up. if i had to guess how it got this bad. probably the old carpet and the road flares left in there. and the antenna holes letting water in. add to all of that, the fact this thing got dailyed during salty Maryland winters.
SonOfaTomP
Baltimore
87 Reliant in a local junkyard. anything useful to get that can be used on these? guessing just the seatbelt covers (they crack) AC controls, radio, and steering wheel?
just off the top of my head:
windshield wiper arms should work i think
the bulbs and sockets from the tailights
fuses
probably the blinker module
window cranks
