I am not building a strip car, this is going to be my daily driver, so I am doing my best to try and gain some good low down grunt! My aim is to have a nice idle, I just don't like the engine idling and it shakes the car cause cam is lopey/choppy not sure what you call it either one of those, hence the decision to buy the truck cam! Don't want a loud exhaust either.
Bruce
There it is!
There are only three realistic and/or affordable ways to get "good low down grunt"
1)Higher stall and/or gears, and specifically a higher TM TorqueMultiplication) in the starter-gear
2)more Static compression, and
3)more Dynamic compression
For a DD, gears is not always the best Go-To.
More Static is always the BEST go-to, but sometimes, the Dynamic has to be considered first. A cam with a later closing intake (ie bigger cam), always always always, moves the power to a higher operating rpm, and with no other changes,sacrifices some low-rpm power to get it. Low rpm power is "grunt".
Increasing the Dynamic always increases the grunt. But the dynamic can only be increased to a point, and then it can create detonation issues.
So getting grunt with a particularly sized engine is a bit of a balancing act.
A lower starter gear is the number one go to. But if your funds are limited, then this too is a balancing act.
Ideally we need a 4-gear automatic. This can tighten up the power band, or broaden the application. For the same reason that the old 2-speed PowerGlide was retired, the 3-speed automatics should also be.With 4 gears, we usually get a lower first gear and an overdrive. The lower first gear combines with the current starter gear to deliver about 12% more starter-gear. But the overdrive allows a further increase in the rear gear of 45%, to get the same final-drive. This is phenomenally HUGE. The usual procedure is to split the difference; with half going each way.This gets you a lower cruising rpm and still a lot of grunt off the line.
Here is an example;
Suppose your current rear gear is 2.94 and your trans ratios are 2.45-1.45-1.00. This would make your road gears then;7.20-4.23-2.94.
Now imagine an A500 with ratios of 2.74-1.54-1.00-.68od. Again using your 2.94s, the road gears would be 8.06-4.53-2.94-2.0; there is your 12% better first gear. Plus a bonus of the 2.0cruiser gear. But say you were happy with the 2.94 final drive of the first combo. This would allow you to install 4.30s in the rear for a cruiser gear of 2.97, close enough. But the starter-gear would now be 11.78! This is a 64% increase from the original 7.2! This is like increasing your engines torque output at stall,also that same 64%, but the TM continues thru each gear. For a streeter and a DD this is waaay too much. For a 360 automatic, a starter gear of 10/1 is plenty.
So working backwards,with 3.55s,we get a starter-gear of 9.73, and a final drive of 2.41;a very nice compromise. 3.73s would also be acceptable. In fact 3.91s are about the limit. So let's see what the roadgears would be with 3.73s; I get 10.22-5.74-3.55-2.54. Compare that to your current 7.2-4.26-2.94.
The first gear has 42% more grunt, second has 35% more, and direct has 21% better, and the cruise rpm is 14% lower. And the engine remains exactly the same. What you get is more footpounds to the road in every gear, and the lower cruise rpm should translate to more mpgs.
Now I realize that this thread has just taken a serious turn.But IMO, for a DD you just can't beat TM.
A similar result can be had with an A998/999. You get the same 2.74-1.54-100 but without the OD. This will get you 12% more take-off grunt. this is like switching from 2.94s to 3.29s, without changing the cruise rpm. The 2500 stall would add it's own TM,perhaps another 10 or 12% so now you are up to over 20% additional TM. If you then increased your rear gear also say to 3.23s, another 10%; now you are over 30% better first gear grunt. This is sorta like bolting a turbo-charger onto the current combo. The 3.23s will increase your cruise rpm tho; some 10%, or perhaps 250 rpm@65mph.
All of these changes are bolt-ins.And the A998 is a non-loc,up,so it will accept your 904 TC.
The only realistic engine option that will maybe touch this, is a fast-rate-of-lift cam of the same stock .050 intake duration but with less advertised duration. Closing the intake earlier will increase the Dynamic compression ratio to a higher than stock number, giving you more cylinder pressure and hence more grunt. To be really effective this would need to be a fast roller cam. So as to your original question; you were on the right track. But it will in no wise come close to 30%.
Working with small blocks, I have done it both ways. If I had to make a choice between one or the other,(stall/gears or compression) it would be very difficult. But; I had to do the DD thing with a 318 for 5 winters in a row, and IMO, TM cannot be beat. Even a lo-C 318 with 4.30s and double overdrive is downright mean, And when you add a clutch to it, well, that's just icing on the cake.
