bremereric
FMJ Body Moderator
Believe it or not I got new ones at JC Whitney.
Unsnap and remove the metal master cylinder cap. Get a level and place on the master cylinder top and measure both ways. Raise car accordingly. It doesn’t need to be exact. I have feeling it is close already.The car is sitting on 4 jack stands. I suppose I could get a level and adjust accordingly.
NOTE: do not leave a brake master cylinder cap off for long and always tighten the brake fluid bottles tightly after each usage!
What happens is brake fluid likes to absorb water moisture – which is bad.
One - it lowers the boiling point of brake fluid.
Two - when water is in a boiled state – it is still water (in this case not mixed in with brake fluid at the time). What does water and steel/iron like to do when together – RUST!
Rubber seals/parts constantly rubbing against rust OR against a smooth rust free bore – which will wear out the rubber faster?
A lot of manufactures say to change the brake fluid every couple of years – mainly because of the water moisture absorption reason – but not all do.
The only thing I see in my FMJ service manuals is to inspect the master fluid level (only) every six months.
I don’t go out of my way to change my brake fluid often but it does get changed every few years due to stuck brake calipers, leaking wheel cylinders and the occasional rusted brake line.
That said and looking at my past repair history, it may be in my best interest to change brake fluid every couple of years . . .
 She purrs like a kitten. I was having difficulty trying to find the timing settings for it. The emissions label is long gone and there seems to be allot of speculation on the web. Then I read somewhere you can set the timing using a vacuum gauge, so this is what I tried. Mostly what I read lead me to believe the timing should be between TDC and 5 Degrees BTDC @ 750 rpm. When I tried this, the engine was sluggish and read @ 14" or less and would stall by barely tapping the throttle. I adjusted the distributor and got the manifold vacuum up to about 20" and she was running like a champ! So this is where I set the timing. Problem is, the timing mark seems to be way off and the engine compartment is so tight I can't barely see the timing marks with the power steering and air pump brackets in the way. I know the timing is well beyond either 10 degrees before or after TDC
 She purrs like a kitten. I was having difficulty trying to find the timing settings for it. The emissions label is long gone and there seems to be allot of speculation on the web. Then I read somewhere you can set the timing using a vacuum gauge, so this is what I tried. Mostly what I read lead me to believe the timing should be between TDC and 5 Degrees BTDC @ 750 rpm. When I tried this, the engine was sluggish and read @ 14" or less and would stall by barely tapping the throttle. I adjusted the distributor and got the manifold vacuum up to about 20" and she was running like a champ! So this is where I set the timing. Problem is, the timing mark seems to be way off and the engine compartment is so tight I can't barely see the timing marks with the power steering and air pump brackets in the way. I know the timing is well beyond either 10 degrees before or after TDC  I can't see the timing mark anywhere. I think I committed a boo boo too, by using manifold vacuum and not port vacuum. I'm reading now that this could be an issue. No matter, the car is being towed to another storage spot closer to home and I'll be able to fine tune it there very soon.
 I can't see the timing mark anywhere. I think I committed a boo boo too, by using manifold vacuum and not port vacuum. I'm reading now that this could be an issue. No matter, the car is being towed to another storage spot closer to home and I'll be able to fine tune it there very soon.I would say there is an extremely good chance the outer balancer ring has slipped (no longer clocked to the inner hub) and if so, you will not be able to set timing off of the timing mark on balancer mark.Problem is, the timing mark seems to be way off and . . .
