any one have knowledge of a food online wiring guide I kinda need some help
armataz
springfield OR.
OK, decided to strip down the S/E for the interior parts I need. because I can also use it for the duster. the duster is an A/C car too so it will use some of the part I got from the LaBaron. hopefully I'll have both my blue wagon and the duster back on the road this summer.
also because most of the le barron parts I bought were rust rotten.and no longer worked
armataz
springfield OR.
pulled the seats, wire harness, heater box and most if the plastic out of the SE and I have all the melted parts out, I just need to pull the speedo cable and burnt harness out. to start putting the service wagon back together looks like early summer and it will be back to work. I'm driving her now for short hops just to maintain her mechanics.
the track rails for the bucket seats are good, but the seat frames were rotten(guess the foam held water and rusted them out) I have a set of black high backs. that I'll mount on the rails and string new bailing wire to the slide releases.
armataz
springfield OR.
the SE might still make a good custom build if some one is interested. stick in a duster dash kit from year one and some scrap yard buckets. it has a steering column stripped 225 and trans I wont be using.
armataz
springfield OR.
I found another set of gages off e=bay, for the lebaron panel, but I dint realize the OD was digital any one know if it would work with the non digital harness? it is only an 86 MPH gage, but I dont plan on burring the needle too often, LOL thanks
armataz
springfield OR.
well, heres something new then, it has a digital OD and other than that, it looks like the correct cluster
this was the one that was all rusted out so I cant use it. for comparison
It is the correct cluster but the digital odometer is completely custom. They never came that way so whatever they did for the harness would have been custom too.
armataz
springfield OR.
well, in that case, I dont see any differences in the circuit boards so I'm going to assume it is safe to use. if it lights up, or not wont really matter. since it's not the original miles any way. thanks. TAZ
