Solid Pucks
I have a set not-for-sale, but I do have the "blueprints" which CuddaZappa published on our Dippy.org forum...you'd have to get someone to make 'em for you...local tool&die shop might from iron/aluminum stock?
brotherGood
Urbana OH
I had thought about getting a quote on them from my local machine shop..just didnt have the exact plans for them.
brotherGood
Urbana OH
So you thinking about getting some made ? Firm feel kinda pricey in my book .
Yeah, i'd been thinking about it. Considering the cost of poly bushings though, unless there pretty close in price..i'll probably just stick with the poly. I've not heard enough of a difference between solid and poly to justify it.
I have a Firm Feel setup. All I need is a bit of encourement to get up and put ‘em on.
Another setup would be a very nice for my other car – but FFI’s cost too much for me currently.
I’d rather not go Poly – but don’t have any good reasons not to.
Anything has to be better than 40 year old rubber.
MiradaMegacab
Long Island NY
Firm Feel
those look just like the ones on my workbench - just waiting to install themselves . . .
They could be made – if someone had “material” to work with.
Need to look at mine again, but I think there was a inner lip made on mine – that I don’t see in the picture.
If one had access to a metal lathe – then flattened the sides – they would be easy to make (note: I have no metal working experience – only wood working experience – so don’t take my word for it). I just hadn’t seen material around to work with that size, before.
brotherGood
Urbana OH
Are they solid aluminum? I can see if I can get a hold of the girl whos dad works at the welding shop and see what he can do. Alternatively, the guy I took my heads to last, thats a machine shop..he does everything there. He may be able to do them. If they can, ill get a quote and pass it along
MiradaMegacab
Long Island NY
Those are solid aluminum Firm Feel units.
There are raised pads that locate the K-Frame.
These. are 1 5/16" tall.
That dimension can be changed, for example, increasing the height to 1 3/4" tall will give more clearance between the valve cover and power brake booster.. also giving more clearance from carb to hood..
Darter6
I bought the poly bushings thru Summit for the K frame and torsion bars bushings for my 79 Cordoba for less than $100. Prothane is the brand.Plan to install them next month.Got to be better than the almost 40 old rubber. I did not get the rear bushings or spring isolators yet but they have them too.
