I feel like I finally accomplished something today. Unfortunately, first thing this morning, I discovered that I do not have a flexplate that will work with my torque converter. I'll order that tonight. If I'd had that, I might have even gotten the engine completely installed today.
So, other than finishing engine setup (TDC, plugs, and so on), I did the final test fit. Once I bolted the engine up to the trans, everything came together. With everything lined up the way I wanted it (almost, more on that below), there's an appropriate distance between the balancer and the K, the headers (a-body Hooker Super Comps) fit with no trouble at all (it was surprisingly easy to fit them, of course, I have the manual steering which helps). The only clearance issue I had was the passenger's side custom mounts that the previous owner welded in, so I'll trim those down, then I can move the engine over to the passenger's side a little more where it should be. Then, no trouble at all.
I even test fit the clutch fan and radiator. Even with the extra plate thickness, it looks like it's all going to fit just fine. That surprised me a bit.
Oh yeah, the one problem I did run across is that I'll have to cut a small hole in the motor plate to use the stock mechanical fuel pump, or use an electric pump. I think the hole will be small enough that it won't cause a problem, but I'll judge that once I get the rest of the plate cut.
As soon as I get that correct flex plate, I'll be on my way to what should be a fairly trouble-free-ish install!
And no, that transmission lying there isn't the one for this car. That's a big block 727... I have five or six random transmissions lying around in the garage. The only place I had for that one was literally between the cars. It's ridiculous.
