how the ignition box works...
it controls the NEGative side of the coil..
when it sees the small AC signal from the pick up coil go over 1/2 volt Positive.. the power transistor inside the module connects the negative side of the coil to ground.. this completes the circuit and creates a magnetic field in the primary windings in the coil.. when the AC signal from the pick up coil drops to 0. the power transistor switches off and releases the ground connection to the negative side of the coil.. this causes the magnetic field to collapse through the secondary and create a high voltage spark.. the ac signal from the pick up coil continues to 1/2 volt negative.. then swings to 1/2 volt positive again as the reluctor tips start to line up again. turns on the transistor . as soon as they line up.. the voltage drops to 0 and the coil fires again..
testing the module.. take it off.. take it to a parts store.. they have an automatic tester for ignition modules..
testing on the car... with a digital volt meter.. unplug the pick up coil... set the digital volt meter to 2K ohms.. measure the resistance of the pick up coil usually around 980 ohms.. but anywhere between 500 and 1500 is expected..
before disconnecting.. flip the meter settings to 2 volts AC or 20 volts AC.. crank the engine.. or spin the distributer shaft.. see if you get really close to 1.0 volts.. i like to see just over 1.0 volts AC voltage...
if the pick up coil resistance measures out ok... but does not create 1.0 volts AC it won't trigger the ignition module to turn on the power transistor to charge the primary windings (complete the circuit to ground) so there will be NO spark .
the reluctor can fail..
you can.. with the distributer out.. spin the shaft with the pick up coil connected.. and the ignition coil will spark if the system works..
Read more:
http://forums.moparmusclemagazine.com/70/9048145/mopar-engines/318-has-no-spark/#ixzz334YgjOxe
