I dont understand all the money being spent. Why not just got back to an $50 oem double row set and buy another $25 fuel pump and if the cover does need a little clearance spend 30 seconds with a die grinder?
I can see a lil wear area possibly, hard to tell in pics. I just dont get why a new cover would be needed when the old one has worked for how long?
Well first off holy spare parts! lol
That is alot, and of course confusing but ill try to clarify as much as i can.
The reasons im getting the new cover is to rule out possible cause, based on the condition of the cover i have a feeling this was opened up a few times before I did it.
The outer edge of the cover is fairly chopped up, you can see some of it in the picture along the edge of the cover. And just trying to avoid future issues with the crack the current one has as well. I dont mind spending the little extra to avoid leaks and having to go through all this again lol
As for the oil slinger yea i know what and where it is, or would have been rather, looks like a small plate with a lip roughly 3-4" across. Im assuming it was never equipped or was removed when the double roller was installed.
Maybe i should have worded it differently. I just meant that other than the chain and gears, the only other parts under the cover were the eccentric/eccentric bolt and the little eccentric cup that acts as the bolts washer(Which i realize seeing that quote i forgot to mention the "cup" washer)
From my understanding from other posts the oil slinger is not needed and is actually omitted in some years of the 318.
It also was not equipped with a tensioner assembly, only the oil drip plate that drips on the crank sprocket.
I do apologize for picture quality, google pixels are supposed to have great cameras, and they do, but the site lowers the resolution of pictures when posted.
That said i will try to get a better picture of the wear pattern on both the eccentric and the fuel pump.
As for the fuel pump, its only driven maybe a grand total of 250kms and was one of the first things i replaced when i got the car. It is a Carter M60519.
Prior to this aftermarket timing set, it never tapped, or at least not audibly. I did think recently that the chain had started tapping, turned out it was the lower alt mounting bolt, twas loose.
The HD pumps that you have, i cant find any information on them (assuming that the number around the body is a model#)
I looked into replacement pumps similar to what you have with the arm divot when this all started, they almost all range from 270-350$ Cad. And all the normal OEM style ones or similar design are solid arms like my current pump. Correct me if im wrong but i would likely need a fuel regulator if i went to any of those Hd pumps no?
And as for an OEM double roller kit, i had no luck finding any OEM units. I did that first before going aftermarket but settled with aftermarket when i had no luck.
But seriously thank you for going out of your way to take a look at all this stuff. If you have or can get links to a fuel pump/ or oem chain set by all means post them and ill post results.
Also if you want any pictures of anything specifically let me know and ill get them.
I agree that there is not much going on with this setup and should be fairly easy to diagnose, thats part of the reason for the frustration lol
