this is what i'm busy with
I hadn't been looking you have gotten a lot of work done. The only thing I was thinking about was the lateral bar behind the door opening, did you tie it to the body in any way and also the pillar bar at the windshield?
It looks as though you could use some more X bracing in the rear across your down tubes and then back to your cage.
9secRR
Saskatchewan, Canada
they are the long valve W2"s. PM me for his cell #.
the cage got tagged for 8.50. no X bracing is required. post 32 and 35 show how i tied it all to the frame.
9secRR
Hughes Engines
not much happening this cold long winter up here. i managed to order this cam from Hughes Engines. should perform nicely with the W2's
the shipping is worth more then the cam to Canada ($170 to ship) so i got it sent my in laws in Mesa, AZ. for $19.
9secRR
I finally got some time to work on my 360. Block was honed. Crank was polished. New main/rod bearings. New file fit rings. It’s all I can do till my in laws come home from Arizona. They got my cam and headers. Once I get my hands on the cam, I can get the short block complete.
9secRR
i followed the instructions that came with the rings. they have the ring gaps listed for how much NOS or boost that is going to be used.
...so 2nd gap wider or narrow then the top?
For a number of years, maybe still, there was an on-going debate around the contribution the 2nd gap makes. I set my gaps wider, as per the SealedPower (R-9343 25, file-fit) ring pack I ran. The question, if I remember correctly, revolved around the wider gap either:
1) contributing to removing excess gasses from the 1st ring, thus allowing it to sit more square in the bore and sealing better
2) allowing more oil to get past it and effectively contaminating the mixture, and contributing to detonation
For what it's worth I never an a gapless design...been wondering if that is something I should try in my next build.
9secRR
top ring gap is smaller then second ring gap.
i talked to several engine builders around my area. most said that for what i'm doing, a gapless design is not needed.
9secRR
This is the cam card from Hughes Engines. Little bit bigger then what I ordered.
I thought it was gonna be 615/621 lift with 1.5 ratio rocker. Everything else is what they said it was gonna be.
I would definitely check valve clearance.
How much compression does your motor have?
Ha...pretty narly cam...I love it!!!
I run their much smaller hydrualic flat tappet, the HE3844AL, although it wasn't until I tossed the 4K stall converter into the coupe that things really woke up.
9secRR
off the top of my head, i think compression is at 12.4:1 with the W2's.
i ran 2 sizes smaller solid in a 410 stroker a few years back. think it was 250/256 dur @ .050. 9.5 comp, 3.55 gears, 3800 lbs it ran 12.0's at 116 mph.
...i ran 2 sizes smaller solid in a 410 stroker a few years back. think it was 250/256 dur @ .050. 9.5 comp, 3.55 gears, 3800 lbs it ran 12.0's at 116 mph.
Whaaaaatttt????
You ran that big of a cam with a measly 9.5 static CR??? Heck, I won't even start asking for what the potential dynamic CR may have been, but what about cranking pressure, any readings from that?
Seem like that would have been just much too small of a static CR to make that big of a cam work...???
9secRR
no idea what cranking pressure was. i had Hughes stage 3 CNC eddie heads, 1.6 ratio rockers, hughes stage 2 ported super victor, 1-5/8'' headers, 950 pro systems carb, 4200 tcs stall, stock suspension, 3.55 8-1/4'' diff, 3800 lbs.
i just looked up what cam i ran. HTL 5660AS.
1.5 rocker 572/582
1.6 rocker 610/621
256/260 @.050
it ran really good for a low comp engine. with a set of 4.30 gears it would have hit 11's easily. a good Ultimate Convertor would have made a huge difference also. i had 26% slippage at top end with that TCS convertor and 3.55 gear. 60' was 1.70 best.
4speedjim
Portland NY
That sounds so Healthy, Happy, and Angry the hair is still standing at attention on my arms. And there is their salute to you. Well done sir
